Diebold-Yilmaz index
Re: Diebold-Yilmaz index
Could you post the data?
hello.I have two problems.when i run DYindex using eviews,there is a error message"@row is not a member or procedure of GFEVD ";I don't know how to solve it? another problem is that i can't identify number of lags.I am grateful if you can help me .thanks a lot!
What is the eviews version you are using? Can you run example program dyindex_ex1.prg?
If you have the old version, try to upgrade it to the version 10.
dakila wrote:What is the eviews version you are using? Can you run example program dyindex_ex1.prg?
Thank you for your answer,I upgrate it and solve above questions.But I get another problem,how to calculate “directional spillovers”,"net spillovers"using eviews, could you teach us how to calculate dyindex12 using eviews?
paolo.zanghieri wrote:thanks a lot. Just a final clarification. the series pc_i_J must be interpreded as share of unit i's variability due to j? Moreover each column in the fromvar (tovar) matric is the chare of variance due to (contributing to) other units, right? thanks again
pairwise spillovers =net pairwise spillovers ?
pairwise spillovers =net pairwise spillovers ? what 's the difference between them?
Read the paper. it is different.
how to choose number of random orderings (18=default),I use two variables,monthly data.please help me !
Did you read the document pdf? Use random option. For example,
dyindex(random=18) 2 @ rrdjia rrftse rrfra
I can't find the instruction file. Does anyone have the pdf file?
C:\Users\...\Documents\EViews Addins\Dyindex\Dyindex.pdf
The dyindex add-in is updated. It now includes 'open docs' button and some minor bug fix.
In Diebold-Yilmaz (2012), there are Total Spillovers, Directional Spillovers, Net Spillovers, and Net Pairwise Spillovers. Can we calculate the others spillover index too using this add-ins?
Can we save the total spillover index result in spreadsheets if we don't run it using rolling windows?
Dear guys,
I write to you because I have a problem with this add-in. When I run the add-in with eviews 10, the following error appears: "Error 127 in encrypted program". In particular, this error appears when I select the Generalized IRF for all the variables (x1,..,x6) with a lag of 1. To be clearer, I also uploaded my Eviews file. Thank you for your help.
- DY_example.WF1
- (19.99 KiB) Downloaded 562 times
Users browsing this forum: No registered users and 35 guests
