Hi all, I try to learn panel regression. But, I can not understand that when we should use weighted and non-weighted in running the regression for panel data. Because, I find that there are many option in equation estimation windows for choosing such as cross-section (three options: none, fixed effect, random); period (three options: none,fixed effect, random) and each of them has another option: weighted and non-weighted.
So, could you guys help me to learn when we should choose weighted and non-weighted.
Thank you so much!!!!
When using weighted and non-weighted on Panel regression
Re: When using weighted and non-weighted on Panel regression
I am not expert, but from what I know, if you select the weighted option you will estimate a Weighted Least Squares regression (WLS) which is a special case of the Generalised Least Squares Method (GLS).
It is used in case you have detected the problem of heteroskedasticity in the cross-section or period dimension. Through this method the equation is transformed, which results in residuals being omoskedastic (which is what we want).
EViews Help decribes briefly the different estimation methods in the section titled 'Panel Estimation', so you can have a look there.
Also, I am sure you can find info on GLS methods and fixed VS random effects models in any econometrics textbook (try looking in the chapter on heteroskedasticity and the chapter on panel data).
Hope this helps.
Hope this helps.
christina.sakali wrote:I am not expert, but from what I know, if you select the weighted option you will estimate a Weighted Least Squares regression (WLS) which is a special case of the Generalised Least Squares Method (GLS).
Hope this helps.
Hi Christina,
Thanks so much for your sharing. I will looking for the textbook as your suggestion!
have a nice week!!!!
Users browsing this forum: No registered users and 22 guests
