I have an ARDL model for inflation and output gap using the autolag select based on the BIC, and I want to compare the model against the AR model (no output gap). Is there a quick way to compare these two models in the command line? I can't seem to find how to extract the selected lags.
Ex. if the ARDL model is ARDL(n,1), I want to compare it against the AR(n) model.
Thanks!
comparing ARDL model vs AR model
Re: comparing ARDL model vs AR model
What does compare mean in this sense? Just estimate the two equations and display them side by side?
Hi Gareth,
Yes, estimate the two equations side by side, and compare forecasting properties (RMSE)
Estimate the two equations and have them open next to each other.
Is there a way to do so in the command line? I want to incorporate it into a loop.
equation eq1.ls y c ar(1 to !n)
show eq1
equation eq2.ardl(deplags=!n, reglags=!n) y x
show eq2
Thanks Gareth!
The problem with that code is that the ARDL model selected isnt necessarily the one with the largest lag. For example, the max lag specification I gave was 4, lags, but Eviews picked ARDL(2,0) based on the BIC. Is there a way to recover the "2" from the ARDL(2,0) model selected, and use it as input in my ar equation?
equation eq1.ardl(deplags=4, reglags=4) y x
show eq1
'use !n as the lag that was autoselected by Eviews
equation eq2.ls y c ar(1 to !n)
show eq2
- Untitled.png (1.65 KiB) Viewed 5317 times
There isn't an easy way. You could freeze the output into a table and parse the table, or use eq1.@varlist to retrieve the list of selected variables and parse that.
Thanks Gareth!
I froze the table, and parsed the lag number using the @mid string function.
Users browsing this forum: No registered users and 24 guests
