Greetings everyone, I have a problem regarding the contradiction between the Johansen test result and granger causality ECT result.
Based on the Johansen test result, it show that there is 1 long run co-integration. But, when I proceed with granger causality based on VECM, the coefficient of ECT is insignificant, means that there is no long run co-integration.
May I know how can I justify this? Is Johansen test just a preliminary test?
Thanks in advance.
Johansen and Granger causality test
Re: Johansen and Granger causality test
What you need to know is that cointegration implies Granger causality.
However with cointegrated data in a VECM, it is difficult to interpret Granger causality as performed by Eviews. Eviews by default tests Granger causality on the first differences, excluding the error-correction term.
If you are interested in Granger causality in cointegrated VARs, I suggest the Toda-Yamamoto test. A post by Dave Giles will show you how.
Users browsing this forum: No registered users and 33 guests
