Error Correction VECM
JMar
Postby JMar » Tue Nov 29, 2016 8:20 am
I have this Table and I need to explain the numerical values, and interpret them.
Is there an error correction mechanism?
https://imgur.com/a/f95Oo
And I don't know how to interpret these values.
Before that I had a
VAR Residual Serial Correlation LM Tests https://imgur.com/a/fqWHy, I concluded that there was no serial correlation (because the p-value are >5% for every lag except for lag = 3). Am I right?
A Trace Test https://imgur.com/a/VPLQr
We can reject the null hypothesis "None", and so that there's one cointegrated equation because the p-value > 0.05 (at most 1) so we can't reject the null hypothesis. Am I right?
Thanks in advance (and sorry for my english)
jmagomez
Re: Error Correction VECM
Postby jmagomez » Mon Dec 05, 2016 12:25 pm
Dear JMar,
Could you send me these images at the reply.
The link is not working.
Regards.
JMar
Postby JMar » Tue Dec 06, 2016 8:21 am
Thank you for your reply,
I've attached the images to the post.
Thanks again.
jmagomez
Postby jmagomez » Thu Dec 08, 2016 12:33 pm
Dear JMar,
First:
The parameter values of the independent variables are positive (the true values are the inverse of what it is shown). All these variables have a positive relation with dependent variable.
Second:
Could you make EigenValue Test?
Regards.
JMar
Postby JMar » Sun Jan 08, 2017 8:16 am
Thank you very much for your answer jmagomez.
Users browsing this forum: Google [Bot] and 11 guests
