Quantile Regresssion on Panel data
I am not familiar with high level mathematics, i want to apply quantile regression on stacked panel data. option is available in eviews 8. i have applied the same on my data and calculated the results i have not sure results are valid or not as such no literature is available on quantile regression on panel data. please help me.
Re: Quantile Regresssion on Panel data
The quantile regrssion in a panel structured workfile is simply pooled estimation. It takes no account of the panel structure of your data.
Dear Sir
thanks for your answer. does it mean that it is not considering time factor and it is normal cross sectional regression. if is a cross sectional regression then can the result which i am calculating is valid.
EViews Glenn wrote:The quantile regrssion in a panel structured workfile is simply pooled estimation. It takes no account of the panel structure of your data.
Thanks for your answer. does it mean that it is not considering time factor and it is normal cross sectional regression. if is a cross sectional regression then can the result which i am calculating is valid.
It's a pooled. There is no account taken of the time or cross-section of a given observation.
Good afternoon
Suppose I write the following code:
or
won't that be equivalent to panel with fixed effect?
I'm just curious about it.
equation qpanel.qreg y x @expand(var01)
or
equation qpanel.qreg y x c @expand(var01,@dropfirst)
Users browsing this forum: No registered users and 22 guests
