URGENT ARDL interpretation Issue
Haim Rik
Postby Haim Rik » Thu Jul 13, 2017 9:01 am
Hi Everybody,
I'm performing an ARDL and I made "ARDL Long Run and Bound Test" with Eviews and juste after my "Conditional Error Correction Table", I got this message for some of my variables:
Variable interpreted as : Z = Z(-1) + D (Z)
So I'm not able to see the coefficient for example for Z(-1) to perform a Wald test for example and D(Z) to interpret for the short run the impact on my dependent variable.
How can I do to see these different coefficient ? Or How interpret ou understand that ? No effect on the short run?
Please I need an help
Aimeric
Capture d’écran 2017-07-13 à 11.11.15.png (21.22 KiB) Viewed 3281 times
Capture d’écran 2017-07-13 à 11.20.33.png (20.14 KiB) Viewed 3281 times
EViews Mirza
Re: URGENT ARDL interpretation Issue
Postby EViews Mirza » Mon Jul 17, 2017 4:20 pm
This just means that if your model has variables which are chosen to have zero lags, they have a special interpretation. In your particular case, for instance, the coefficient associated with INV** is -0.117421. The note basically says that:
-0.117421 INV** = -0.117421 INV(-1) -0.117421D(INV).
Accordingly, the coefficient estimate of INV(-1) is the same as that reported for INV**. I hope that clarifies the issue.
NipNip
Postby NipNip » Thu Aug 03, 2017 10:00 am
Does this mean that the coeficient of D(inv) is equal to zero?
-0.117421 INV** = -0.117421 INV(-1) + 0 D(INV).
EViews Mirza
Postby EViews Mirza » Thu Aug 03, 2017 10:23 am
NipNip wrote:Does this mean that the coeficient of D(inv) is equal to zero?
No! It means the coefficient on D(INV) is the same as for INV(-1). In other words, -0.117421. I made that explicit in my previous post.
NipNip
Postby NipNip » Thu Aug 03, 2017 10:35 am
Thanks.
NipNip
Postby NipNip » Thu Aug 03, 2017 10:48 am
I've tried to do the ECM regression in excel, but I think I'm calculating the variable "CointEq" in a wrong way. I think I cannot follow what the equations say in ARDL chapter from Eviews user guide.
Please, can you guys help me with equation used to calculate "CointEq" variable?
I'm using Case 5: Unrestricted Constant and Unrestricted Trend.
Regards,
Joel
maymay
Postby maymay » Thu Sep 13, 2018 6:55 pm
EViews Mirza wrote:This just means that if your model has variables which are chosen to have zero lags, they have a special interpretation. In your particular case, for instance, the coefficient associated with INV** is -0.117421. The note basically says that:
in ecm regression, there is no estimation of D(inv). Does this means there's no short run impact for INV?
