How do you specify identities in command/batch mode
neilblake
Postby neilblake » Thu Oct 09, 2008 12:58 am
Doe anyone know how to specify an identity for a model using a command? The mannual gives an example of how to add the identity Y=cn + I +g to a model interactively but I can't figure how to do this in batch mode
Re: How do you specify identities in command/batch mode
Postby EViews Gareth » Thu Oct 09, 2008 8:05 am
You can just use the append command to append text, such as an identity, to your model:
model01.append @identity y=cn+i+g
Riaz
Postby Riaz » Mon Sep 13, 2010 2:04 am
Does it make any difference if we take out "@identity" in the line above?
Ta
Postby EViews Gareth » Mon Sep 13, 2010 8:12 am
If you take out the @identity, the text will still be added to the model, but not as an identity.
Riaz
Postby Riaz » Tue Sep 14, 2010 10:45 pm
Will the calculations be any different whether we append it as a simple equation or through @identity? Ta
Postby EViews Gareth » Wed Sep 15, 2010 7:24 am
Stochastic simulations will have no random component if the equation is an identity.
Return to “Models”
