Model generating NA values
Tom_Crane
Postby Tom_Crane » Wed May 14, 2014 1:47 am
Hi there,
I've recently been given a new work laptop, on which I've installed eviews and continued working with a database and model our company built a few years ago in eviews. The exact same file and model and solving method as I'm using works fine on my colleague's new machine, but when I hit solve on the model it comes up NA generated for each time period and each variable (of which there are 288).
I'm having this problem on both eviews 6 and with a demo version of eviews 8, so could it potentially be something to do with my computer's settings?
Any help would be much appreciated.
Regards,
Tom
Re: Model generating NA values
Postby EViews Glenn » Thu May 15, 2014 7:10 am
Tom, is there any chance we can see the workfile? It's hard to say without seeing the model and data.
aroncaglia
Postby aroncaglia » Fri Jan 01, 2016 8:32 am
Hey there,
I have been facing the exact same problem as Tom has. I have created values for each of the exogenous variables used in a 3-equation model in order to perform dynamic solutions and endogenous forecasts, but seem to fail whenever I try to extend the forecasting sample to out-of-sample range. What was the problem with Tom's solution above?
Or, even, should I send you my work file so you could take a look at what I have been doing wrong?
Thanks a lot.
André
Postby EViews Gareth » Fri Jan 01, 2016 11:49 am
Every case is different. We'll need to see the workfile
aroncaglia
Postby aroncaglia » Fri Jan 01, 2016 1:02 pm
I tried to send you the work file through a private message, but the website does not allow for wf1 extension. How should I procede?
aroncaglia
Postby aroncaglia » Fri Jan 01, 2016 1:05 pm
You can run either model for a endogenous forecasting to see the problem I have mentioned. How should I send the file? It states that extensions wf1 are not allowed.
Postby EViews Gareth » Fri Jan 01, 2016 4:55 pm
The variable d_2001q3, which is an exogenous variable, has no values over the solution sample.
aroncaglia
Postby aroncaglia » Fri Jan 01, 2016 6:13 pm
Thank you very much. It all works fine now. Have a great year!
Return to “Models”
Users browsing this forum: No registered users and 8 guests
