Solver has stalled
Solver has stalled
Postby tvonbrasch » Fri Jan 08, 2016 3:22 am
Hi again
This adds on to the post viewtopic.php?f=10&t=13749.
I have stripped down the model in viewtopic.php?f=10&t=13749. so it now only consists of 7 equations.
When running the model in the attached workfile I get the error message:
Solve terminated - Solver has stalled: starting values may be too far from a solution
The block structure of the model looks like this:
Number of equations: 7
Number of independent blocks: 2
Number of simultaneous blocks: 1
Number of recursive blocks: 1
Block 1: 1 Recursive Equations
pm92c(7)
Block 2: 6 Simultaneous Equations (2 feedback vars)
bh11(6) bh92s(4) di89(5) bh43(1) bh91s(2) di11(3)
Interestingly If you remove Block 1 from the model Eviews has no problems with solving the model. Block 1 consists of the equation
0 * pM92C + pv92S = (m92u * pM92U + m92c * pM92C + pE92S * e92S + pFT92S * ft92S + pF92S * f92S) / x92S + zlw92S * w92S / 1000
This equation does not depend on any of the variables in Block 2, so why is it suddenly a problem for Eviews to solve the model when this equation is included? (as I showed in viewtopic.php?f=10&t=13749, TROLL solves this model without difficulty). There must be an error somewhere.
I have tried to reduce the model as much as possible so that you can take a look and try to find what is causing this error.
model_will_not_solve_iii.wf1
(108.61 KiB) Downloaded 494 times
ElsaP
Re: Solver has stalled
Postby ElsaP » Tue Jul 18, 2017 6:06 am
Hi!
I actually have the same problem. I am working on an improvement of a part of my model written in EViews and am defining some new variables. I just wrote a new line and it will give me "solver has stalled [...]" but when I don't include this line, the model is able to be solved and when I do the maths of the new variable I am trying to define, it works.
It can't be that I miswrote it since the model runs until 2020 (instead of 2050).
Have you found any explanation to your problem ?
(I am seriously starting to get crazy)
Elsa
Postby tvonbrasch » Tue Jul 18, 2017 1:30 pm
Hi Elsa,
sorry, i did not find the answer. You should upload your workfile to the Eviews team and let them try to figure out what is causing the problem
Return to “Models”
Users browsing this forum: No registered users and 24 guests
