EViews 9.5 not running Census X-11/X-12
dieuler
Postby dieuler » Fri Oct 28, 2016 6:47 am
I had a program which run normally in earlier versions of eviews (9 or less), but after I updated to 9.5, I can't run them anymore. This is the message that appears to me:
Any guess? Thank you in advance.
Re: EViews 9.5 not running Census X-11/X-12
Postby EViews Jason » Fri Oct 28, 2016 11:11 am
Sorry but your image is not visible.
dieuler
Postby dieuler » Fri Oct 28, 2016 11:31 am
Sorry, I posted it as attachment now. Hope it worked.
Postby EViews Jason » Fri Oct 28, 2016 2:44 pm
If you do not mind, please send an email to support@eviews.com. I would like to determine when the problem was introduced.
You can otherwise copy your entire EViews directory to a directory that does not have spaces in it such as c:\temp. This should fix the problem.
